ECC83 replacement
menamestommenamestom Frets: 4705
I need to change the V1 preamp valve in my PRRI, what's a good replacement for a Fender amp?
I guess any will do, but what sounds good for reasonable money.  JJ?
The outgoing valve is a Fender Groove Tubes / Sovtek 12AX7WC
I would consider a reasonably priced NOS, but I'm not sure those really exist anymore.
  • SunDevilSunDevil Frets: 511
    A lot of the modern valves are basically rebrands of the same thing
    you basically have a choice of Chinese or Russian
    I'd suggest trying JJs and Sovtek LPS and see what you like
  • ecc83ecc83 Frets: 1636
    Bit OOTouch these days but the TAD 7025 HG I always found quiet and reliable, not a bad price either.
    N.B. When you change the valve run the amp for several hours and drive ***t off it if you can (actually make a noise and shake it)
    I found a good 25% of the front end valves I fitted went noisy, usually a low level crackle/burble after such a test.
    Dave.
  • CollingsCollings Frets: 411
    I find anything other than JJ to be ok in the preamp. Im currently using Tungsol. To my ears the JJ is a little to dark.
  • DJH83004DJH83004 Frets: 196
    +1 for Dave on this one, Whilst I fit JJs (Slovakia by the way not Russian), for longevity the TAD 7025s do get the vote from guitarists that I work with. I am not a fan NOS valves, simply because the vast majority end up being microphonic - IMHO.
  • uncledickuncledick Frets: 406
    EHX suit Fender preamps pretty well imho.  Seem quiet with a bit of sparkle which JJs don't seem to have.
    I wouldn't want to replace @ecc83, he's too knowledgeable :)
