Anyone had any luck removing, concealing, filling a scratch in nitro finish, ....?
Fishboy7Fishboy7 Frets: 2228
, .... say if someone had dropped a pair of heavy pliers on the top of an otherwise pristine R9, ....
  • FunkfingersFunkfingers Frets: 14632
    How deep is the scratch? Just the finish or into the wood? A fill and buff repair might be sufficient.
  • Fishboy7Fishboy7 Frets: 2228
    just the finish, ... 1 maybe 2 mm
  • thermionicthermionic Frets: 9686
    Nitro lacquer melts when you add more lacquer, so it’s probably easier to get a good result with a dropfill than on a poly finish.
    is there a product you'd suggest for filling, ...then sandpaper or steel wool for buffing?
  • BrizeBrize Frets: 5636
    Yes, I had JXG drop-fill a dent in a gloss R8 a few years ago after my daughter chucked an iPhone at it. Worked a treat.
    She really didn’t like it then....?
  • merlinmerlin Frets: 6792
    I hope you took the dent out of the iPhone by flushing it down the toilet.  ;)
  • richardhomerrichardhomer Frets: 24854
    Apply a sticker to obscure the damage?
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • John_AJohn_A Frets: 3775
    An expensive guitar like that, I would get a professional to do it, it's not hard, but wants doing properly
  • IamnobodyIamnobody Frets: 6914
    edited May 2018
    Sounds like the start of a relic project...
    Just get a big spanner and twat it all over. Job done.
    I do have an SG that’s had a dent in the neck filled by a previous owner. You can’t feel it but you can see it.
    Previously known as stevebrum
    I thought R9’s came with lacquer dings out of the factory..?
    Presumably, pulled off pot shafts are an aftermarket optional extra? ;)
    ha, ... that did cross my mind actually
  • spark240spark240 Frets: 2097
    I had exactly this in my new PRS 513....I got Jamie Davey to sort it and honestly cant tell it was ever there...depends where you are based, he's in the Midlands.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    Can you post a picture of the damage? A flash coat repair may be achievable
  • MistyMisty Frets: 135
    Don't do it yourself unless you are 100% confident and experienced. The repair can easily end up looking worse than it does now. Get a pro to do it. I speak from bitter experience.
    Thanks. I've decided to leave well alone.  If I come to sell it I'll get it touched up by a pro.
  • scalino65scalino65 Frets: 261
    Depends what colour the area where teh ding is. If its black, then you could drip a little black nitro onto the area using the end of a toothpick. If its part of teh sunburst, then it becomes much trickier to match the new colour. The really fiddly bit comes next, once teh new paint is slightly proud of the old, you have to flat it back using a very, very small object as a block. Its a bugger of a job really and is very tricky to get perfect. Definitely worth checking with a pro.
    In flattening the repair back it's very easy to make the scar bigger, or even go through to the wood like I once did. Also there's a tendency to get impatient and do it before you've got enough nitro in the ding, or before it's properly hard. Another risk is that, in flattening it back then polishing it, you end up with it looking nice and shiny but with a dent where you flattened it. Good decision to leave it alone!
