Annoying playing issue with my J45 - help appreciated
  • ICBMICBM Frets: 72510
    camf said:
    Thanks @ICBM. Looks like a new nut might be worth a try. I suspect for some more refined players the string spacing might be fine but it does look quite a bit closer to the edge than the ES-125. I think something with a spacing more like the ES-125 would suit me a lot better although I'm guessing that might also entail a fret dress (although I think that was done not so long ago), a check of the bridge and maybe a general setup too. Are you busy? :)
    I should be able to do it fairly soon - the workshop is a bit full of large amps just now.
    Maybe next week...
  • camfcamf Frets: 1191
    Cheers John, that would be great. See you then.
    cam
  • p90foolp90fool Frets: 31632
    If the top E string is not actually slipping off the fret end then I'd be looking at the string sliding along the saddle as the source of the pinging tbh.
    I know you said you checked the bridge saddle, but can you reproduce the exact sound by deliberately moving the string from side to side at the saddle?
  • earwighoneyearwighoney Frets: 3497
    edited May 2018
    camf said:
    The nut is standard 1 3/4" I'm not really sure how I'd measure the spacing.
    If you have digital calipers then use them to measure the E to E spacing at the nut.
    But I'd like to add that a new nut with narrower string spacing could be the solution.  If you have calipers yourself and can do a few mods yourself then you could get a premade one from Christ Alsop Parts like this
    I bought one myself with wider spacing than I had before.
    I just saw you have ICBM as your local repairman, take the guitar to him instead!
    I'd actually had @ICBM have a look at the bridge before, when I was still trying to identify the problem. He gave it a clean up and smoothed a couple of rough spots but it still hasn't solved the problem. At that point I hadn't considered that the problem might be at the other end.
    edited May 2018
    Thanks @earwighoney. It will be off to @ICBM next week for some TLC.
    Isn't that something he should have checked by default?
    If I had actually noticed a problem I would have :).
    Chasing this kind of thing can be tricky if it's caused by - and this is not a criticism, we all do things slightly differently - the player's exact technique.
    I just had another one where the owner was finding a choke at around the 15th fret on a Tele. I couldn't get it to do it at all, but when I handed him the guitar it was really obvious. All in the different ways we attack the notes, I think.
    edited May 2018
    Yep, update on this. As I should have done before, I recorded some songs on the J45 and did some proper analysis. Consequently, I realised the problem was occurring pretty much only when I was playing an open D chord - which, as a singer, is quite often. I think I just need to check my wrist position and see how it goes. Although I’m always going to leap to @ICBM’s defence - he doesn’t need it but he’s been a huge help to me for around 30 years - he’s entirely right on this again. Even with just knowing where the issue was, I’ve been virtually able to erradicate it. Even I couldn’t work it out or demonstrate it when I took the guitar to him. When he played it, it sounded fine.
