Just one more . . .
Paul_CPaul_C Frets: 7793
We all know this is a lie ;) but I'm pretty sure that right now I only need one more pedal, either a Mad Doctor Stutter or a Boss Slicer - unless anyone knows of another pedal which will chop up a drone signal.
It won't stop me buying other pedals, which @VJIves will be pleased to hear, but in terms of something which will add something that I don't currently have, I'm not sure there's anything out there that does something that I can't get close to, other than those two.
    the slicer is a wonderful thing.
    Its a bit big but its cool as.
    The M5 can do a similar thing too with its pattern tremolo
  • VJIvesVJIves Frets: 466
    The Slicer is a brilliant pedal.
  • JezWyndJezWynd Frets: 6083
    The Slicer is cool but I found it got old really quickly. The sound has a synthetic quality that was wearing after a while. Stimulating pedal to play around with though. It’s been a while but... would it work with drone like sounds? I seem to recall it needed staccato style notes to work best.
  • EricTheWearyEricTheWeary Frets: 16297
    The stutter effect on the Mooer Mod Factory is supposed to be good if you fancied going cheaper/ smaller on this.
  • Paul_CPaul_C Frets: 7793
    Thanks for that, it might be worth a try at that price - space isn't a problem.
  • BeexterBeexter Frets: 599
    The Zoom multistomps have a slicer built in...
  • joetelejoetele Frets: 951
    +1 for the Zoom Multistomp - it doesn't matter whether you buy the 50 or the 70 version either as the patch software updates are available for both. I use mine for the Slicer and Bitcrush settings, along with some reverse recerb. Genuinely good bit of kit which gets full use in my band.
    MUSIC: Pale Blurs
  • FunkfingersFunkfingers Frets: 14465
    JezWynd said:
    Slicer ... would it work with drone like sounds?
    Yes. It just gates them. (The clue is in the name, folks!)
    EHX RTG > EHX Pitch Fork > BOSS Slicer = self-playing step sequencer burbling sounds à la Jean Michel Jarre.
    Add a wah filter and you can make Pink Floyd VSC3 style effects.
    The Slicer can be synchronised to the tempo of your DAW software music project. The EHX RTG cannot. No points for guessing that this is where things get interesting, if slightly odd. Luckily, the Slicer has its own loop recording capability.
