Price depends on quality to some extent. The Ernie Ball ones are built like tanks, the Morley one is just pressed steel. You pays your money, etc etc.
Good points: it's unpowered, and you can adjust the minimum/floor setting all the way from "off" to "virtually as loud as full on". The latter function is great if you want to have fine control between "loud" and "louder".
Bad points: there's relatively little resistance in the pedal, so if you have it configured to do "off" to "max" rather than "5 to max" or "7 to max" as above it's far, far too easy to make large adjustments in your volume when you don't mean to.
Actually, thinking about it, it doesn’t really need a centre detent. All I need is something that will allow me to set a minimum and maximum volume and give me the full sweep of the pedal to vary between those two points. I suppose the maximum setting is probably irrelevant as there seems little point in having a volume pedal that doesn’t give you full volume when it’s on full!
All it’s for really is when I find a combination of effects / patch on my multi-fx is too loud or quiet, or I need a boost for solos, and I’m not going to bend down and turn knobs or fiddle with the amp in the middle of it. I always run my guitars at full volume on the guitar pot - it changes the tone too much to use it as an actual volume control.
If anyone has a pedal with a minimum volume knob, what happens with the sweep I found you set a minimum volume ? Do you get a nice, gradual increase over the full sweep from your set minimum to max, or is it that the pedal movement from zero up to the set minimum point does nothing and only when you reach that point does it increase the volume?
Offset "(Emp) - a little heavy on the hyperbole."
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
The FV-50H I use does exactly that. You can set the minimum volume on a wheel (0 - 10) and you then get a smooth sweep from the set "min" all the way up to "max".
With "min" set reasonably high (5+) it's quite usable because the difference isn't too great so if you have elephant feet you won't suddenly knock all your signal out with a tiny movement (of deafen everyone if going the other way).
As above, I find that if you have "min" on 0 to give you a full sweep from off to max then the lack of physical resistance in the pedal means it can be a little too easy to be heavy-footed.
But if you're basically wanting to use it as a more fine-tunable boost switch, and you play with it on your set "min" and kick it up to "max" when required, it's fine, and cheap as chips (or mine was).
