Big flashing knobs ( it’s an OD question BTW)
EricTheWearyEricTheWeary Frets: 16298
edited June 2018 in FX
watching bands last weekend there was some obvious foot stomping going on for solos . I have tended to eschew the overdrive pedal but I’m now thinking it would just make things a little easier. However, in the doom and gloom of a pub I’d like something hard to miss - an easy to spot and stomp footswitch ( preferably huge and glowing) and a pedal that lights up like a Christmas tree when it’s on. Boost/ low gain kind of area.
It’s the hard to miss aspect that’s the important bit. Although probably not just a massive box, still has to go on a Pedaltrain Jr along with my assorted random other crap.
Anything out there that fits the bill? Ta.
  • HattigolHattigol Frets: 8189
    edited June 2018
    Specsavers have 2 for 1 at the moment...?
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
  • EricTheWearyEricTheWeary Frets: 16298
    I am picking up some new glasses from them next weekend as it happens.
    Very dissapointed by Big Knob Pedals brand that seem to have quite normal sized knobs.
  • ICBMICBM Frets: 72486
    Keeley Mod Boss SD-1.
    Bright yellow, huge footswitch, blue LED that could guide a 747 in to land...
    Known as the seeing eye mod apparently!
    I'll watch some YouTube although my expectation of the DS1 is that it's a bit more high gain than I'd be looking for ( but it's has knobs).
    SD-1, not DS-1... :)
    He does both, the SD-1 is more what you're looking for I think - basically a Tube Screamer-family overdrive/boost.
  • paulnb57paulnb57 Frets: 3055
    edited June 2018
    Boo TS 808 with illuminated base?
    Base is permanently lit...led shows effect on or off.......
    http://booinstruments.com/guitar-effects/od-ts-limited-edition/
  • VoxmanVoxman Frets: 4726
    BBE Boosta Grande - really bright 'on' lamp too!
  • poopotpoopot Frets: 9099
    Get yourself a light plate for the bottom of the pedal.
    The issue with really bright leds is that in a dark venue, if the peda is on and the led is shining it’s really hard to see past the blinding light to change any settings!... not just on the pedal that’s on either!...
    i have a delay on my board that ive taped over the led because it is so bright when it’s on!....
    Or if your handy with a soldering iron get these...
    https://guitarpedalparts.com/product/3pdt-foot-switch-with-led-ring-red/
  • stickyfiddlestickyfiddle Frets: 27133
    MXR Micro Amp. Big and white and 1 knob so you can't really get it wrong. It sounds good and you can adjust it with your foot if you need.
    I'm not actually sure why I don't have one atm
    Ha! I blame Google. I used to have an SD1, not really sure why I sold it.
    That’s excellent but ‘handy with a soldering iron’ is not a description usually applied to me :anguished:
    Ahh, forgotten them - always liked the glowing plate look.
    The big orange one would be hard to miss!
    You do see them on a lot of pro rigs.
  • benmurray85benmurray85 Frets: 1396
    If you’re in a band that’s playing in pubs and you can’t see a pedal you really should be looking at improving your lighting setup rather than worrying about a boost for solos!
    How very rock and roll
