This is a good example of how being scientific about music often makes you totally wrong.
CirrusCirrus Frets: 8493
edited March 2014 in Theory
I see this kind of thing all the time of forums.
Here we have a study in which it's concluded that a Stradivarius Violin sounds worse that 20 other good, modern violins. It's very well presented, great lengths went into ensuring the experiment was a true double blind test. On the surface it's pretty watertight - the 300 year old violin, worth $10m, was far and a way the least preferred by all the players involved.
Except for one small detail that IMO renders the whole experiement void.
It was done in a small hotel room.
«134
  • monquixotemonquixote Frets: 17632
    But being scientific isn't the problem here is it.
  • CirrusCirrus Frets: 8493
    edited March 2014
    Let me explain my point further then. Quite often people think they're being scientific, but in doing so miss some massive variables that mean their conclusions are wrong. In this case, they haven't considered that a violin needs to sound good in a concert hall, and also needs to have a tone that fits well with an orchestra, which is a wholly different ball game than sounding pleasing in a little hotel room. In my opinion, they're using the instrument incorrectly.
    A common forum example is when people post frequency response plots to try to "prove" that one speaker sounds the same as another - they think that the science is all done for them and they can make safe conclusions, but the resulting graph leaves them blind to so many other variables.
    In this case, lay people may read the conclusion and take it at face value. I'm not trying to argue that a 300 YO violin is worth ten million dollars - I'm just saying that it's a good example of how evaluating something like tone using objective means can fall flat on its face.
  • frankusfrankus Frets: 4719
    Is it about not having the right mushroom to make yourself smaller and the room relatively bigger?
    Imagine the looks on the trustee's faces when you return their Strad to them, shrunk to the size of a matchstick. ;))
    I would say it's an example of the scientific method working.
    They submit their findings for publication.
    You critique their experiment for failing to take into account the  properties of the room.
    A follow up experiment can be devised to test the impact of the room of the perception of quality of violins (repeat in different rooms and see if the same results are obtained) this may invalidate their previous experiment.
    This is a strength of science.
    A non scientific approach would be worse because you have no proper methodology to critique you just get "I am an authority on violins and I say Strads are great/shit delete as applicable"
    edited March 2014
    I hope it does, fucking whitecoats lording over everyone.
    I hope they do a control experiment in a vacuum too..
  • Is it something to do with mids, did the Strad have mids on 10?  I bet the modern one had scooped mids which sounds nicer on its own but in a mix it just doesn't cut it because it is all about mids.
  • guitarfishbayguitarfishbay Frets: 7961
    edited March 2014
    My favourite graph based fail post on a forum was a guy blaming their 'spike' near 20khz as the reason V30s are so harsh.  Wish I could find the thread, think it was TGP
    I think Bucket has a 500 fret guitar that has a spike at 20khz
    Bucket has a guitar with just one spike? chinny-reckon. ;)
  • imaloneimalone Frets: 748
    Science: here's what we did, here's what we think it means.
    Accepted wisdom: here's what you should think.
    Lording?
    Sorry, I don't think I've got your point. Could you be a bit clearer?
  • mike_lmike_l Frets: 5700
    You not heard of the 8000 fret spike guitar? Do keep up Frankus. :P
    Two points I suppose.
    One, telling people what they should think, particularly on the basis everyone should obviously prefer the Stradivarius because it's expensive, comes closer to what I'd think of as "lording it over everyone".
    Two, I don't like being referred to as a "fucking whitecoat".
    Cheers.
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    edited March 2014
    Oh my god, you're seriously offended? Were you involved in the study?
    Sorry man. It was meant in jest. What area of science are you involved in?
    I wasn't telling people what to think, and I didn't express an opinion as to which violin is best as I'm not qualified to make any claim there - just pointed out the obvious flaw in the study, which is that room acoustics and context are vital. I tend to take it as said that everything I write is my own opinion, and it's supposed to invite discussion rather than demanding everyone holds my view.
  • That's as may be, but I think it's fair to say this test is very, very close to being conclusive.
    Okay, so they didn't do it in a concert hall.  Then again, unless playing a solo piece, it would be mixed in with so much other stuff, surely the sound becomes less relevant?  I always say, with guitar, the finer nuances are generally lost in the mix, so I would say it's the same with violins.
    And if playing a solo piece, it would be mic'd up - and eq'd.  So... That's not strictly just the instrument you're hearing, and acoustic guitarists are always talking about which mic to use, mic placement etc. What PA would be used?  What if it's the wrong type of PA for that violin? Who's the sound man, and how does he think it should sound?
    I'd say a hotel room is as good a place as any, and the fact that everyone said it was not so great speaks volumes - is it fair to assume these people were professional violin players and, therefore, knew a good sound when they heard it?  If they played it in a concert hall, would the argument then be the concert hall didn't flatter that violin, and they should have done it in a whole range of concert halls?
    Science like this really needs some element of acceptance because to do all of that would cost stupid money.  And people who think Strads must sound better will still think it because there will be, somewhere, a small hole in the experiment. This experiment is as good as there is any point in doing - common sense should prevail in light of the evidence, and others will keep talking about the holes to prove otherwise.
    Imagine (shock horror) if instrument building at the top level has improved over the last few hundred years.  Who'da thunk it?  I think it's fair to say we live in a golden age of music, where a low quality instrument is as good as what used to be mid or top range, and a top range one is incredible, made to exacting standards by people who have been handed down hundreds of years worth of experience.
  • Here, however, is an example of what you mean.
    They conclusively, 100% PROVE with science that the tone woods sound different
    And yet they say the evidence proves they don't  ¬_¬ Never understood this one, but I assume they have no idea how the dB system works.  Some frequencies on some strings are 6dB different!
  • goldtopgoldtop Frets: 6158
    You make a good point,but out of interest, how do you know they were, as you put it "totally wrong"?
    You cannot conclude that, just by identifying a potential problem in the face validity of the test. You can't know that if they did it again in a concert hall with audience they would get different results.
    FWIW, I went to a demonstration of Stradivarii and other vintage and some new violins hosted by the curator of the Royal Academy of Music's violin collection, and the Strad was not the favourite of either the concert violinist playing them, not the audience. (Subjective.)
    No worries, had left it a while to see if it looked tongue in cheek, but couldn't get it, and you'd be surprised the attitudes some people take. I'm in a completely different area, medical imaging in dementia (mainly MRI).
    Agree with the spirit of your thread, people need to be able to look critically at studies.
