Does this Strat exist?
HootsmonHootsmon Frets: 15977
Looking for a not too expensive Strat to see how I get on with one....
Can be a MIM or USA
Nitro finish
9.5 radius
Rosewood board
I kinda like the look of the vintage small button tuners too....
anythin' out there that ticks most ^  boxes?
tae be or not tae be
  • munckeemunckee Frets: 12400
    MIM 60s roadworn has all but i don't know the radius.
  • sweepysweepy Frets: 4189
    Highway Strat would fit the bill
  • thermionicthermionic Frets: 9658
    edited June 2018
    Classic Lacquer 60s, but they have a 7.25” radius board (never bothered me, I have 4 Fenders with the vintage radius and I’ve been able to set up all of them well). Older ones will have a rosewood board, newer ones Pau Ferro.
  • lovestrat74lovestrat74 Frets: 2530
    7.25"
    You could probably make it exist with a partscaster for under £500 - that way you get what body, neck and pickups you want ;)
  • Don't dismiss  a 7.25" if you haven't tried one.  You might find some of the models mentioned here will suit you. Good luck.
  • crunchmancrunchman Frets: 11459
    The new American Original is nitro finish and 9.5" radius.  The 60's version has rosewood board.  Seems to tick all your boxes depending on how you define not too expensive and whether it is within your budget.
    Why don't you want 7.25" radius?  Is that from actual personal experience, or just internet perceived wisdom?  I really like 7.25".
    You have more options to choose from if you look at 7.25" radius.  You have all the AVRIs over the years, which would be good value second hand.
    If you like totally unrealistic relicing there is the roadworn series.
    There is the also nitro finished lacquer Strat:
    https://www.musicradar.com/reviews/guitars/fender-classic-series-60s-stratocaster-lacquer-579776
    The latest version of that has a Pau Ferro board because of CITES, but I doubt you would be able to tell the difference in blindfold test.
  • SNAKEBITESNAKEBITE Frets: 1075
    This ^^^
    SNAKEBITE said:
    This ^^^
    It has a horrible 70's headstock (unless it's one of the really early ones).
  • rossirossi Frets: 1704
    Highway Ones ended up with jumbo frets too.
    The Highway Strats I have worked on have had medium frets and small headstocks, they are a bit of a bargain tbh
  • camfcamf Frets: 1191
    If you're in Edinburgh at all, come and try mine.
