Locking tuners ?
baldybaldy Frets: 195
I am after a set of locking tuners for an old LP copy (Hohner), they are 6mm post diameter, 22mm shaft length with 2 diagonally opposite screws.
These look to be the same as what are on the guitar now but I do not seem to be able to find them in a locking version  https://www.ebay.co.uk/itm/NEW-Vanson-VN21-Tuners-Machine-heads-for-Acoustic-or-Electric-Squier-etc/111173064988?hash=item19e26e591c:m:mCznV6HG4Xazdeo3ifUv6uQ
Any suggestions would be great.
Image result for Vanson VN21 Tuners image
  • baldybaldy Frets: 195
    Are locking tuners available in this size/style as I don"t want to be drilling/filling holes really ?
    Oh & if somebody could confirm that they can see the picture that would be great as last time I posted pics I could see them but nobody else could.
  • DrBobDrBob Frets: 3006
    I can see the pics, but I’m afraid I don’t know whether you can get locking tuners in that size !
  • DiscoStuDiscoStu Frets: 5523
    edited June 2018
    I can see your pic fine, @baldy .
    I'm not sure you can get locking tuners with 6mm post width and screw in bush. Any that I have seen/used have had a 10mm width at the hole with a washer/locking nut on the front. If you're happy to increase your headstock holes to 10mm (if not already) then take a look at the tech specs on this page to find best fit. You might be left with the top screw holes showing but with cool tuners on will it really matter?
    https://www.axesrus.co.uk/3-x-3-Machineheads-s/1917.htm
    Yes I could put Wilkinson WJ01 EZ-Lok tuners on it if I wanted to drill out the post holes & have 1 screw hole per tuner showing.
    I was hoping for a locking tuner that was a straight swap really.
    Not a criticism, but why locking tuners? I’ve always found them to be a pain in the arse to be honest. A decent locking string wind and you get a better anchor anyway...
  • FelineGuitarsFelineGuitars Frets: 11600
    You will find that most locking tuners need a 10mm hole as DiscoStu said
    You may get some Kluson style ones that have a 6 mm shaft but the footprint will differ from what you have there
    Can understand just going without but what's the down side of locking tuners?
    Btw you don't have to drill if the holes are too small, get a reamer tool for a couple of quid and it just takes a quick turn of that in each hole.
    Might just be me ;) but I found them a faff. I found they didn’t save that much time, they can be a bit heavier and it can affect balance, and as has been said after fitting it’s usually not a reversible mod.
  • SteveRobinsonSteveRobinson Frets: 7039
    Also they introduce more moving parts, bits to fall off and lose, threads to damage etc. Some (usually when they get old and worn) struggle to grip lighter strings.
    I had them on one guitar and one absolutely point blank refused to grip my g string.
    Oooh Matron!
    I have put locking tuners on a few guitars now, Wilkinson ones, & have not had any problems.
    I find string changing much quicker & easier with locking tuners & have had no problems with the ones I have fitted or the guitar I have that came with locking tuners.
    I re-strung the Hohner last night & thought to myself what a faff compared to my guitars that have locking tuners.
    Just my experience.
    Just my experience.
    Oh it’s definitely horses for courses - if they work for you then that’s a good thing.
    Bit worrying that they lose their grip over time. I tend to install them on every guitar but I've got one that doesn't have them yet and I might not bother
  • VoxmanVoxman Frets: 4725
    Depends on type. The locking tuners on my PRS Cu24 are superb and make string changing a doddle. Conversely the Grovers on my Yamaha Pacifica 611vfm are good bit a bit of a faff.
    I don’t know how serviceable they are.. @SteveRobinson  May know..
    I have 3 guitars that I have fitted Wilkinson EZ-Loks to, 2 Superstrats & a LP copy, & a Yamaha Pacifica 611 that came with locking tuners as standard & don"t have a problem with any of them.
    YMMV.
    edited June 2018 tFB Trader
    My favourites are PRS phase 1 locking tuners.
    I quite like Planet Waves Auto Trim tuners except that it's impossible to remove strings and put them back on again, or even slacken them much when working on the guitar.
    I've find that tuners that use a cam mechanism rather than a pin tend to be better, with the possible exception of Gotoh Magnum Lock which are in my experience poor at gripping the plain strings.
