    At least the neck is in one piece
  • mikeyrob73mikeyrob73 Frets: 4671
    And that my dear @bridgehouse is because MJP Turner is Welsh and not Irish
  • poopotpoopot Frets: 9099
    They build guitars for “privet” order... that’s why it’s pictured in the undergrowth!.
  • ICBMICBM Frets: 72448
    edited July 2018
    That's a really good place to put them. You can easily 'roll' the controls with the side of your hand quickly without interrupting your playing too much.
    It's a bit like the toggle switch position on a PRS - it looks odd, until you use one and then you realise it's the best place of all.
  • AlexCAlexC Frets: 2396
    edited July 2018
    Might have to dip into my hedge funds to buy one then.
  • TA22GTTA22GT Frets: 362
    I'm sitting on the fence with this one......
    edited July 2018
    It doesn't seem that bad to me
  • thermionicthermionic Frets: 9656
    Yeah but MADE IN WALES so I won’t hear a bad word said about it.
  • CasperCasterCasperCaster Frets: 762
    Presumably it once had a separate bridge ans stoptail and the location hides the original holes for the stoptail. Or maybe there was a flaky bit of timber, or damage/error occured in manufacture?
  • handsomerikhandsomerik Frets: 1007
    Seems alright to me and doesn’t look too odd. Not so sure about the Alfa pots though. I assume they’ll sound as good as the Alpha ones that most people use ;-)
  • frownfrown Frets: 32
    I would’ve just used stacked pots...
  • EricTheWearyEricTheWeary Frets: 16297
    The Duesenberg Julia has the coil split switches behind the Bigsby which looks a bit odd to me, reminded me of that.
  • I keep seeing these guitars on eBay.
    Does anyone have experience of them?
    Don't let your mind post toastee - like a lot of my friends did!
