I recently picked up an ‘89 korean squier strat for £100.
The electrics needed sorting ie pots/switch/cap etc and now its restrung it sounds and plays very very nice / i’ve never been a real strat fan but it does feel nice and i quite like it.
The only negative being the trem - with anything other than a slight “wobble” it drops out of tune.
So, options are upgrade the trem - but, is that worth doing on a lower end guitar and if it is, what should i look for/need?
Or, flog it along with a couple of my other guitars and get a decent basic strat, preferably single coils, rosewood board, medium frets - mex/usa/mij - nothing fancy, just a reliable workhorse.
Any thoughts?
Or just hardtail it.
Is it sticking out of tune in the same direction as the last arm movement, or the opposite? Same - the problem is at the bridge; opposite - the problem is at the nut or machineheads.
I did end up selling as strat was my main guitar and I decided I should have more money in the strat and less in the tele, but was perfectly good. I made back the money I spent on it and learned a lot from the process.
Horses for courses.
I tilt mine upwards by the regulation 3/16ths of an inch.
I briefly owned a late Eighties Fender Big Apple Stratocaster with the fixed bridge. At the time, I blamed its lack of pizzazz on the *spread and veneers* body construction. In retrospect, the absence of springs and a cavity could have had something to do with it.
Gotta disagree with this. Despite making numerous attempts, I have never succeeded in getting a three pickup Telecaster to sound exactly like a Stratocaster without also losing the Tele-ness of its bridge position pickup.
For what it is worth, installing a Tele-inspired bridge position pickup into a Stratocaster also fails to achieve that elusive hybrid Fender sound set. The nearest that I have ever got is a Squier JV Stratocaster with two Duncan APS-1s and a Twangbanger.
Clapton prefers a locked-down trem too. I think it's likely that the cavity and springs do add 'something' to the tone - not least because when the spring vibrate, they're within the magnetic field of the bridge pickup.
I don't like Nashville Teles either.
It's a circle that cannot be squared - a part of the fundamental character of each guitar comes from the bridge, so putting Strat pickups into a Tele or a Tele bridge pickup into a Strat - even a hardtail - won't give you the same sound as the other guitar.
(formerly customkits)
If I could pick out a trem vs hardtail in a blind test I'd believe they sound different.
