I use only lumpwood charcoal and light it with a chimney thing. I'm not a huge fan of briquettes as I have no idea of what they're glued together with. Having said that, I have no idea where my lumpwood charcoal is coming from; for all I know they could be from barrels of insecticide!
Anyhow... I'm having problems.... I light the charcoal with the chimney and by the time the flames are visible out of the top (the supposedly 'ready' point), 70% of the stuff is burning bright orange within the chimney.
Empty the coals and start to cook. Here's the problem... I'll get 20 mins at most from this point before the coals are mostly ash and much cooler. This isn't enough time.
What am I doing wrong?
Anyone suggesting using gas will be ignored for the uncivilised oafs that they are.
thread over
Fixed height grills suck.
I saw them in the shop and and thought 'christ. thats pricey'. Than after a few years of buying lumpwood buy the lorry laod, I purchased a pack.
They will burn for a couple of hours and if you only use them for an hour, you can close the vents on the BBQ and relight the coals next time you have a barbie.
Really are worth the money!
I can cook a whole chicken (approx 40 mins) and then do a "normal" BBQ after. So I get well over an hour without even trying!
I've just bought a 20kg of kameeldoring african wood which is meant to be the mutts nuts for BBQ Not sure I'll be using a chimney with it tho.
Ive been buying locally produced charcoal and have hot coals ready to use in about 8 mins with a chimney starter. When I was using charcoal bought from a supermarket it would take 15 to 20 to get them hot enough to use.
Sunday was chilli and bread, bloody lush it was.
