I replaced my bridge with a Wilkinson. In order to get this to mount centrally, I had to buy the version with the elongated pivot screw holes. I also had to fill and redrill for the screw that passes through the one round pivot screw hole.
One upshot of this is that I have a complete but redundant Yamaha SE vibrato, finished in chrome.
Wilkinson installed. Yamaha resting in humbucker cut-out.
The stock bridge has the skinny, tapered sustain block associated with Sung-il vibrato bridges. I changed to Wilkinson specifically because I want the larger steel block. My intention has always been to have the bridge flush with the body.
In the photograph, you should just be able to make out what I meant about the elongated pivot screw holes on the Wilkinson vibrato bridge's baseplate.
