It works but you got to know this can be a problem.
Variable filter is best for video work and in fact critical for video work but for photos single ND is considered best. I do have one variable filter, a 77mm B+W 1-5 stop ND, it costs a small fortune at like £150 so a good one is not cheap.
Sorry to disagree but i would never in a million years use a variable ND (basically 2 x polas) in place of a single 'proper' ND for video.
Vari NDs are soft, have much more pronounced colour casts and can introduce all sorts of artifacts.
They are basically the devil. Why have a £1,000 lens and put a shite cheap bit of glass in front of it unless it's deliberately to screw an image?
I've a fancy eye watering set of 4x5.65" NDs and grads for video and a basic Lee set for stills.
And then you can't go wrong with a Big Stopper or (my preference for more neutral casts) a Firecrest 8-10 stop for long exposures.
@Grumpyrocker love that last shot mate.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
https://www.bhphotovideo.com/c/product/905893-REG/b_w_661072522_77mm_xs_pro_nano_mc_nd_vario.html
To be honest youtube Vlogging is very very rarely anything to do with having good quality or production values as opposed to having (good or a lot of) content. I can probably count on one hand the number of channels that actually know what they are doing in that regard.
EDIT: Moan over
I do sometimes use a single 10-stop ND for effects on clouds and water. It wasn't hugely expensive but am happy with the results.
Jesus how do you link from flickr on this forum without it going mental?
Click the share button (bottom right, swoop arrow symbol), selection the "embed" option, and the size you want (usually 800 wide is about right) then copy the text it gives you.
Come back here, hit the </> button (top right of the edit box), paste in your text, and hit the </> button again
EDIT: Ooh it worked that time. Thanks
The other option is to paste just the direct link from the embed link (the bit from http:// to .jpg") and use the insert image box in the forum
