Analog Delay Recommendations...
challenchallen Frets: 51
I use a Way Huge Aqua Puss for slapback. I like the way it sounds but the volume drop when I turn it on has always bugged me a bit. Anyone got any recommendations for a similar sounding pedal without this annoying quirk? The more simple, the better. I'll only be using it for slapback.
Cheers.
  • GassageGassage Frets: 30928
    Skreddy Echo
    Carbon Copy
    DMM
    ADRX20
  • RiftAmpsRiftAmps Frets: 3171
    Vahlbruch Spacetime
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • peteripeteri Frets: 1283
    Best two I ever had -
    Cheap(ish) - Carbon Copy, so good I ran two at one point
    Analogman ADRX20 - large, but a thing of beauty
    Ha! Large by a straight man’s standard...
  • builttospillbuilttospill Frets: 457
    Boss DM-2w or Big Box DMM
  • challenchallen Frets: 51
    edited July 2018
    Thanks for the recommendations, I should add that space on my board is tight so it can't be any bigger than the 'Puss.
  • John_PJohn_P Frets: 2750
    DM2
  • bwetsbwets Frets: 162
    If you need modulation then Carbon Copy if you don't then DM2-W.
    And pink by anyone's ;)
    Back on topic - how about the Ibanez mini analog delay? You could have one of those and a TC Mini in that space
    DOD rubberneck
  • WazmeisterWazmeister Frets: 9568
    Nice board mate - like it...
  • EricTheWearyEricTheWeary Frets: 16297
    Just to say probably not the Carbon Copy. If you hear the Puss as having volume drop you'll hear the same for the CC. If it's primarily for slapback then modulation will be a non issue, the Boss DM2-W probably ticks all the boxes here.
    I'd suggest the Minifooger as it has a built in pre amp but it's large and not universally loved.
  • shaunmshaunm Frets: 1598
    Not quite analog but what about the Mad Professor Deep Blue Delay? It doesn’t sound digital to my ears and it replaced the Carbon Copy I had.
    Looks like I'm going to check out a DM2-W then! Just had a look online, spec looks ideal. Thanks!
    This is also on the list to try, I think a friend of mine has one so will see if I can have a go on that, too.
  • BluesyDaveBluesyDave Frets: 411
    MXR Echoplex.
    No Darling....I've had that ages.
  • I’ve a minifooger for sale in the ad section. Sounds exactly like what you’re looking for.
  • TeetonetalTeetonetal Frets: 7806
    used a few:
    Dod Rubberneck
    EHX DMM 1100tt
    Moore Ana Echo
    Boss DM2 Waza
    Moog minifooger
    Chase Bliss TR
    Of those, if all you want is slapback, get the Ana Echo. Cheap as Chips and easy to use.
    Though the best slapback in my opinion comes from a tape echo, not an analogue one. (my Roland RE501 just sounds awesome for this, though a tad overkill)
  • Ben8010Ben8010 Frets: 150
    edited July 2018
    Just in case you're still thinking about it and haven't pulled the trigger yet:
    I like the Carbon Copy but it's not what I'd use for slapback, it's just a bit too dark sounding and there's better delays out there for that.
    Yeah, the DM-2w is defo a better choice for what you want IMO.
