Nope, all I have is what you see in the pic ^
I’ve been trying to find a technical drawing but nothing out there for this particular valve. Other valves seem to use the same kind of setup but even in the drawings for those it’s not clear how the seal is formed.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F192612713991
Neither of these parts are soft enough to deform under pressure, though. I could very well be wrong but even if they are machined to a tight tolerance, after chrome plating them is that tolerance preserved. Even machined parts usually require a gasket of some kind.
Like I say, though, I could be wrong.
Where you have two very hard surfaces you almost always need a third softer gasket material to do the same job - to deform and conform to the surfaces of the parts you want to join together to create a seal.
High machined tolerances are one thing but as I said before after chrome plating those tolerances won’t be preserved even if they existed to start with. I’m not sure such high tolerances are achievable for £20 a set of valves.
Just stop procrastinating and show us a picture of the installed valve. Or a video if it leaks
It's not a soft material though, I don't know what it's made out of but I tried to nut them up last night and even with a great big spanner and as much might as I could muster I didn't make a scratch in the plating let alone deform anything to make any kind of seal.
I decided to rig one of the valves up to the outside tap this evening and blanked off the other end after the tail.
Turned the water on, opened the valve and not so much as a weep.
I dont understand it at all but it does work! I have properly been stood corrected.
So at mains pressure it seems sound. I guess I’ll have to stop doubting and trust that whoever designed the fitting knew what they were doing.
My apologies to @hywelg for being a pedantic so-and-so in the process, I still don’t get it, it goes against all engineering principles I’ve ever known but work it does!
You learn something new everyday.
