How much does a cutaway affect the sound of acoustic guitars. My observations have been driven by things I'v experienced more than what I hear. I started seeing this over 20 years a go, I was playing a lower end, but well made non-cutaway and a couple of my students had higher end cutaway guitars. Both of them marveled over the "sound" of my guitar compared to theirs, one even wanted to buy it. I suspected that the cutaway might be causing this even though I really couldn't hear enough of a difference to say for sure. Fast forward to today, I'm in a band where two of us are mainly playing plugged in acoustics, both have higher end guitars, mines a non cutaway, the other guys is a cutaway. I plug straight into my amp, or at some gigs the front end, and always feel great about the sound I'm getting. The other guitarist always goes right into the front end and after months of constantly "knob twiddling", he brought an "acoustic simulator" in and now spends half his time playing with settings, trying to get "that" sound. I don't really get it, I think his guitar sounds great plugged in direct and have told him that but....., so, what gives?
Though I wonder if your bandmate's issue is too many options. I'm assuming his guitar has an onboard preamp which gives him a million sounds all of which are probably a bit "piezo-y". If you have a single pickup with just a volume you don't have a choice, so you're more likely to plug it in and get on with the music bit
It also depends on what music your playing, some players just need to get up the dusty end and it's easier with a cutaway.
My objections to cutaways is looks, really - on dreadnoughts in particular they look dreadful.
Richard Thompson’s Lowden has a cutaway and sounds pretty good to me....
I am one of those, but for live playing I’ve learned to just live with it and not worry, if everyone else thinks it sounds OK. It sounds like he hasn’t.
What are the guitars by the way? And/or are the pickup systems different? Not all piezo systems are equally good (or bad, depending on your point of view!).
I highly doubt it’s anything to do with the cutaway, not least because nuances like that don’t come out through a typical undersaddle piezo transducer. There is a small difference in acoustic tone in my opinion, a cutaway tends to reduce bass response slightly.
This first version of the ES has a magnetic pickup under the end of the fingerboard and a couple of 'inertial sensors' in the body. The one under the fingerboard gives it an odd, almost electric-guitar-like tonality when playing on the plain strings around the 10th-12th frets. (This system is also prone to reliability problems.)
Earlier Taylors use a Fishman system with a large preamp box in the side of the guitar and are piezo-based (or combined with a mic on some models), and the new version of the ES uses a piezo sensor in the bridge, but pressing against the back of the saddle - which is what the three small bolts do.
Personally I find Taylors hard to get a natural amplified sound out of, especially the Mk1 ES. I had and older one with the Fishman electrics and was never really happy with it, even after I added a magnetic soundhole pickup as well. But they have a huge number of pro users, so some people must like them...
I'm going to have to take another look at that, I don't recall seeing the three small bolts and I had no idea they used anything but piezo. We've got a gig tonight, I'll ask him. Unlike a lot of guitarists he's not up on the details for acoustic or electric guitars(he actually asked me why the soundman called my "tele" a "tele" at the first gig I did with this band!
I’ve never really understood the logic behind them either - a) who plays lead guitar high up on an acoustic’s neck anyway, and b) why would you need to do so on stage but not at home or in the studio?
I think the logic is that since you rarely do that sort of thing unamplified, the only time you need a cutaway is on an electro-acoustic. I disagree, and it's annoying that it's quite hard to buy a cutaway guitar without electrics.
The shape looks about right, and it seems to have a pinless bridge with a split saddle, and a very hard to access truss rod .
