When the installers fitted the solar panels on our roof a few years ago, they replaced the hot water cylinder in the process. We always had an electric immersion heater in our hot press cylinder 'just in case'. When I checked it out after the fitters had left, the immersion heater did not work so I put it aside as a job to do myself.
Fast forward to today. I got a new timer switch yesterday and set out to install it. No real problems, just 4 connections and that was all there was to it. Except the immersion did not work.
After checking the connections and the supply voltage, I discovered that the cable [about 2 metres long] was open circuit. Luckily I had enough cable in my bits press so the new cable was installed and clipped in place. The immersion still did not work.
The full supply voltage was present at the immersion heater so I moved the thermostatic control until I heard it click. Still the immersion still refused to work. My ohmmeter confirmed that the heater element was intact so there was no alternative other than bypassing the thermostat on the immersion heater. The immersion heater worked! The thermostat is actually not needed in our case as the immersion would not be on for any more than a half hour at a time.
Refitted all the covers etc and all is well in the Rocker household hot press. What should have taken around an hour, actually took half the day. Always remember, if something can go wrong - it will.
Nil Satis Nisi Optimum
Usually if something breaks, I swear a lot, google it, swear some more, get a quote from a real bloke, swear some more, and resign myself to ‘fuck it’ for a few years.. lol
