In that case what is 'Blackie' (made up from 6 guitars) - Granted 'blackie' is not original, but is it now no longer a Fender ?
So what happens if I take a neck of to adjust the truss rod
IMO if you have a host of genuine Fender parts and assemble them as a 'bits o caster' then as long as you are truthful about what you have and describe it as a 'Fender bits so caster' then I'm not so sure there is any issue - After all, if you break it down and sell each part separately then you can legally call it a Fender neck and equally a Fender body etc etc
However I do agree in this instance it is 100% a bits o caster - I have an issue calling this one a Fender Custom Shop Strat - But I would not have an issue calling it a 'Fender Bits so caster'
https://www.fender.com/product-registration/
https://www.guitargaragelondon.com/testimonials
Apparently, the seller is a "Guitar Scientist"...
"Someone on this page referred to Dan as a guitar scientist, and I’d have to agree".
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
I had one of these with the flag pin, and from memory the serial number was also N3 but the date stamp on the heel was definitely 1994.
I've previously flagged some of their listings on eBay for dishonest representation/passing off/ fraud etc. I wouldn't go anywhere near them!
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
https://www.guitargaragelondon.com/custom
Won't be long before the legal dept coming knocking methinks.
What?!
You can see the pinholes for the 40 logo on the original listing. I guess leaving it on would be too much of a giveaway!
