Alternatively you could get something rather fancy like the Ortega Horse kick Pro that had a number of digital drum and percussion sounds. You can run it in you guitar signal path, presumably into s PA or acoustic amp.
It's also not too hard to build your own using a transducer, I did this myself and it worked ok.
I had one of these, they are ok - but around £75.
work best with leather soled boots/shoes
Just picked up a Roland spd kick, which is sample based and way better.
Nil Satis Nisi Optimum
