Stopbar bushings pulling forward - should I be worried?
longjawlongjaw Frets: 423
Just noticed that the bushings on both my MIK Tokais are starting to raise out of their holes (probably from the tension of the strings?).
SG:
http://i.imgur.com/ZUgOLRW.jpg
ES60:
http://i.imgur.com/jdyXAmz.jpg
Not sure when it started to happen as I don't play them that often, but I'm not sure if this is something that needs to fixed, as there's obviously plenty of the bushings still in each guitar.
If it does need fixing I was thinking removing the bushing posts, filling the holes slightly with some thin strips of wood then replacing them back in could fix it.
Anyone else experienced this problem, or any techies able to advise?
Cheers
  • ICBMICBM Frets: 72413
    Stop top-wrapping them. That puts a much greater turning force on the posts and will be contributing to it.
    I usually fix this by gluing them in with epoxy.
  • merlinmerlin Frets: 6691
    Beat me to it!
  • longjawlongjaw Frets: 423
    Cheers all, I'll string em differently ;)
