Brand new PRS, pots reversed
AmblikAmblik Frets: 2
Hi folks, new to the forum. Trying to get back to playing and have picked up a PRS SE custom 24 (new).
Ive had it for a week now and i'll be taking it back in for a proper setup, but one of the things i think is weird, is that the volume and tone pots work backwards. 10 is off on the volume for example.
I'm sure its just that the pots are reversed but it seems odd that it would come from the factory like that. Is that weird? Something to worry about?
Have i picked up a guitar that someone has gutted and returned!?
Just looking for some views on it really.
Thanks!!
  • Winny_PoohWinny_Pooh Frets: 7837
    Sounds like an easy mistake on a production line. If it looks fine and you're happy otherwise then just have the wires reversed.
  • FelineGuitarsFelineGuitars Frets: 11653
    is it a right handed or left handed guitar?
  • grungebobgrungebob Frets: 3351
     do they all move clockwise still to cause an effect? you sure someone hasn't just pulled the knobs off and put them on at a different point in the sweep?
  • AmblikAmblik Frets: 2
    Thanks for the replies, its a right handed guitar.
    The numbering on the knobs ascend clockwise so turning the knob anti-clockwise ascends through the numbers 0-10, as the volume decreases.
    Come to think of it, for the tone, i actually have no idea if its wrong. Is 10 usually more Treble and 0 more bass?
  • blueskunkblueskunk Frets: 2909
    That’s weird as I have a PRS SE Soapbar and that’s like that too. The guitar is very good indeed but I have a new loom coming :)
  • ICBMICBM Frets: 72807
    Turning the knob clockwise should increase the volume. If the numbers go the wrong way then they are left-handed knobs, but this would be very surprising because they’re extremely rare - most companies which make left-handed guitars don’t even use them.
    On the tone control, clockwise should be more treble and anti-clockwise no treble.
    Can you post a pic of the knobs?
  • teradaterada Frets: 5114
    Yup, typical PRS quality control. They have that reputation for a reason  ;)
    I’ll take some pics of my Soapbars pots as they are fooked
    Will post a pic when i get it back. I took it back in for some minor things as well as the pots; truss adjustment, intonation etc.
    One of the things was that one of the pickup ring screws was loose and screwed in at a fairly bad angle. I just happened to mention it when i went in not thinking much of it. Anyway i just found out that they've sent it back to PRS because of that one screw, as apparently "there was a piece of wood missing".
    Not too impressed with PRS quality control it has to be said. I've barely played my new guitar!
  • guitars4youguitars4you Frets: 14529
    Very unusual to get negative QC issues on a PRS - Certainly compared with most other big brand name builders - Not sure if purchased mail order or over the counter, but either way I think it is only fair that they offer you a replacement - Knowing PRS as I do, then I don't think they would have an issue with a replacement, based on your comments above - Assume it is new stock as well
    Yeah it was new over the counter. I bought it in a bit of a hurry so clearly wasn't quite as attentive when i had a go in the shop. Will speak to them when they get it back in. Thanks.
    These are right handed guitar knobs- turn knob clockwise (viewed from above) to increase volume, and numbers increase from the players viewpoint
    Is the numbering on your knobs reversed?
    just don't see why they won't exchange taking into account it has gone back to PRS anyway
  • rossirossi Frets: 1710
    This is terrible .Thank god we have Gibson to set the standard .Since  that Paul  geezer has run PRS I have heard nothing but quality issues .At least we have the internet to  alert us .:-)
  • HenrytwangHenrytwang Frets: 473
    Sorry to hear that. I’ve always found that the quality control of new PRS SE Guitars is about the best for mid priced guitars.
    <pic removed>
    I think they must be left handed knobs! The numbering goes in the other direction.
    Thanks very much for the pic, that confirms it.
  • NikcNikc Frets: 629
    I read this thread and thought Id check my prs and then realised I didn't really care - one way makes it quieter the other louder who's looking at numbers ??
    Just think how rock history would be if peter green had had the internet ;)
  • grappagreengrappagreen Frets: 1356
    And just think if your guitar ever gets to be ‘famous’ everyone will be hunting down reverse knobs to improve their tone at some point in the future :)
    So just pop a pair of right handed knobs on and all is well .
    That is really remarkable. Someone in Korea must have screwed up quite badly to do that, and I assume it applies to a whole production run.
    All that needs to be done now is track down whoever was responsible and make sure the knobs get distributed correctly to the makers of left-handed guitars who never bother to use the proper knobs! (Which is more or less all of them.)
