soundcloud.com/thecolourbox-1
But nevertheless useful to know it can be done
Serious question though - a lot of the YouTube demos show the line outs being run into the front of another amp. Isn't this a bit odd? I thought amps were designed to take much lower than line level, high impedance signals? Have you tried this yet?
Just because you're paranoid, don't mean they're not after youDoes the red box allow you a line output with a normal instrument cable without the cab simulator? Will give it a Google.
Not tried it into another amp but I suppose if you use a multi fx they are usually line level aren't they? So would probably just be like that. You can also turn the volume down I think
Bandcamp
If my L20 is anything to go by it'll do a bang up job as a plain old guitar amplifier too.
No idea if true myself but said gentleman was very enthusiastic about the result.
Thanks yes this does look good too, seem to be rather classy sounding but that could work as contrast I suppose, and have a nice clean
