I fancy a CC-1, but it's a lot of scratch to drop in one go. But the P1 and G2 also look great...
Any thoughts on these pedals ?
@Wazmeister
Looks like the man to talk to is @Gassage and you can see his pedalboard here sporting a few PC pedals
http://thefretboard.co.uk/discussion/comment/118330/#Comment_118330
And the switching *still* isn't as reliable as a boss pedal.
But other than that, I don't think I could justify it - no one seems keen on doing gut shots, but I'd imagine they're mostly simple, classic circuits that happened to be made by the cornish family. The crazy delay one he did, for example, was actually a boss dd-2 that was rehoused and had a couple of mods, which definitely isn't over a grand of work in my books.
Us mere mortals will stick to the more reasonably priced pedals
Thanks for the input guys
How is the SS3 as a 'stand alone' pedal ?
I do have 2 Cornish cables which are fantastically robust, I'd recommend them without hesitation.
Edit: really not sure what it's based on from personal experience but a tech had one said that to me.
By being so expensive and exclusive, and gooping and using a tamper seal, cornish virtually guarantee that no one will look inside to see that they are perfectly ordinary effects. The fact the warranty seal exists should be a warning - if you're on tour, and a switch goes, you could just solder one in... Except you can't, because of the seal. If it's gooped, even harder.
They might sound amazing, but you are paying more for the name than anything else, I reckon.
Or I'm wrong and they have unique circuits and components no one else uses. It is a possibility, but I just don't see it. I would find them better value with a lifetime warranty, too...
Sounds interesting though!
ICBM has a point. There is something quite cool about owning something made by someone on a pro board.
Luckily, most pros have a boss somewhere so I'm happy
I remember dedicating hours to learning sugarfoot rag, and it really dawned on me how much of a genius he is. He does this crazy 1 finger, 2 string unison bend to a major chord that took me a while to master.
