As far as self build is concerned I do quite fancy the idea. So much so that I decided a while ago to build some pedals to refresh my soldering skills in preparation for taking on an amp kit. The pedal kits have sat untouched ever since! I think that illustrates perfectly where I am at with that idea.
The Victoria is sadly over budget.
The other options that have been touted just aren't hitting the spot. Even the Rift and Flynn, which I have no doubt are excellent amps just aren't really tempting me. I can't help thinking that if thebreeze was selling a Fender Champ instead of a Rift it would be long gone by now.
Still not had any real discussion of the quality of these Fender '57 Custom amps. Is that because people don't know, don't care or something else? I suppose if the quality was rubbish then plenty people would be shouting about it so perhaps they can be considered good by omission! lol
I had some kind of attenuator added. It sits between the speaker output and the speaker. Usually I have that set on half, and the amp’s volume on 5. I play with the guitar volume on around 7.
It’s a fantastic amp, but I might not want it as an only amp. It really only does one thing. Or two — warm, direct cleans, and filth. It’s also picky about what guitar you plug into it. Humbuckers are a no-no. I have to turn the bass-cut right up (dowm?) on my Strat to make it sound good.
You’ll need some kind of EQ, then, on the guitar, or in a pedal. With EQ, the Champ is a lot more flexible.
Also, a Princeton Reverb with a master volume mod is a great home amp.
The Romany has another switch for EQ bypass, making the circuit behave more like a tweed one-knob 5F1 Champ.
If you have the budget for a Cornell amplifier and require sonic variety beyond *small tweed*, consider the Romany's close cousin, the Vintage Brown 10.
if volumes not too much of an issue, I had another go of a tweed pro junior and was reasonably impressed with it. A/B tested a 330 and 335, with the volume on about 7 and tone on 4 - good sound coming out
https://farm2.staticflickr.com/1886/43828973844_3f078010d5_b.jpg
Congratualtions indeed.
I'm not an amp expert by any stretch but the clean sound is something else. It is a creamy, warm, compressed clean. Even on a strat bridge pick-up with the treble quite high there is bags of treble but it somehow manages not to sound shrill. That is quite some trick IMHO!
