OD & boost question
HootsmonHootsmon Frets: 15964
Let's say you have 2x ODs on the floor and 2x boosts....a boost at the front of the ODs and a boost at the end
Assuming you have a clean amp only, all pedals off tone,, and one or all ( or any combination) of the ODs and boosts on,how many combinations are possible?
A poor man's multi channel amp switcher on the floor...how many channels?
tae be or not tae be
  • prlgmnrprlgmnr Frets: 3990
    Amp
    Boost 1 -> Amp
    OD 1 -> Amp
    OD 2 -> Amp
    Boost 2 -> Amp
    Boost 1 -> OD 1 -> Amp
    Boost 1 -> OD 2 -> Amp
    Boost 1 -> Boost 2 -> Amp
    OD 1 -> OD 2 -> Amp
    OD 1 -> Boost 2 -> Amp
    OD 2 -> Boost 2 -> Amp
    Boost 1 -> OD 1 -> OD 2 -> Amp
    Boost 1 -> OD 1 -> Boost 2 -> Amp
    Boost 1 -> OD 2 - Boost 2 -> Amp
    OD 1 -> OD 2 -> Boost 2 -> Amp
    Boost 1 -> OD 1 -> OD 2 -> Boost 2 -> Amp
    edited September 2018
    There are 31 possible combinations of 5 things, but 15 of them in this case aren't possible.
    edit: hang on, this is only if order doesn't matter which in this case it could. Assuming order is fixed I think my list is ok.
