WTB: Strat Harness
Looking for a decent 5 way harness/loom with quality pots and switch. Don't mind if has mods such as, bridge/neck blend, treble bleed or tone on the bridge.
  • FunkfingersFunkfingers Frets: 14466
    Budget?
  • ZoolooterZoolooter Frets: 887
    Depends on what it is I guess. New, decent ones go for about £55 to £65 -  so less than that.
  • FelineGuitarsFelineGuitars Frets: 11600
    Got a new full one with pickguard and Mex H/S/S pickups for £100
    To clarify, I just need the harness. I have pickups and pickguard. Cheers
  • Bump
  • Bump
  • I'll check my parts box when I get home to see what's in stock.
    I haven't done it for a while but I used to make and sell these...
    Do you need the jack or is it just pots, cap, and switch?
    Cheers,
    Matt
  • Hi there, jack not essential. Just needs to have decent quality parts and .22 cap with a no-load tone pot on the bridge.
    Cheers
    Russ
  • Ok I'll price that up and get back to you
    Scrap the above suggestion I made about the tone on the bridge and no load pot. Now I just need a standard harness with neck middle with separate tone controls and master volume. If you have .022 cap great, if not .047 will do. Basically what ever you have in the back of the cupboard!
  • Ok, so I have no 250k CTS pots left, but that simply means I need to order some in any way!
    If you want full bells and whistles I can do you 3 TVT (true vintage taper) 250k split shaft CTS pots, .022 cap, 5-way switch, wired up and sent to your door for £45.95
    I've got .022 Orange Drop caps, or a rather fancy .025 russian military paper-in-wax cap. Might not notice a great deal of difference between the two, but it'll sure as hell make you seem like a right cork-sniffer!
    The opposite end of the spectrum... I can do you 3 Alpha pots with a bog standard mylar film cap for around £25.
    I love a bit of cork sniffing so let's go Russian with full bells and whistles!
  • I'll get ordering! With a little lead time for the missing bits I estimate shipping it towards the end of this coming week if that's Ok?
  • That's great. I'm in no rush, still need to find a neck, knobs and tuners.
    Cheers
