What do you use if anything?
I have 9 pedals, and a dusty room.
Cleaning and general stomping usually ends up in knobs being moved, which is annoying as then all my volume levels in relation to the amp and each other are out of whack and takes me longer than it should to set again... lol.
I’m more of a set and forget type for drive pedals.
I like to keep a constant balance in volume across all pedals and amps own gain.
Looking for cheap options.
I could cut little bits of masking tape and stick them around the knobs to draw a line on, but anything slightly better looking?
https://m.ebay.co.uk/itm/Mixed-Colour-Code-Stickers-Coloured-Sticky-Labels-27-Colours-6-shapes-15-Sizes/180848897909?hash=item2a1b6f2f75%3Am%3AmlkXeYWNELImjJpPD_NUcig&var=480089045343
Super clear on stage day or night.
2. Remove the knob from the shaft
3. Replace the knob so the indicating line is straight up at 12 o’clock.
Now all you have to do if you nudge your settings is set the knob back to 12 o’clock. Simple, easy to do and completely free
I can't possibly say how I know that .
Anyway, I just tend to take photos now. The only problem with this is when you are setting up you look like you are messing about on your phone rather than getting on with it.
Unless I'm being very finicky I tend to point the knobs toward something, so my pedal settings are often based on everything pointing at the LED. I'm sure it's what all the top pros do...
different triangle coloured stickers!!!!!
has worked very well for me.
This will probably also make everything sound better.
There's a company that makes pre-made stickers for this - overkill obv but the control freaks seem to like it.
Another route is use elastc bands round the knobs themselves to stop them turning.
