Recent and prospective R8/R9 buyers - a few tips on setup
TwinfanTwinfan Frets: 1625
Just a quick tip for any recent or soon-to-be R8 and R9 blowout buyers.
My R8 came from Peach and the team there had clearly done a great pre-sale fettle on my guitar.  It played and sounded great out of the case, although I tweaked the action and neck relief to suit my own personal tastes.
My R9 came from GuitarGuitar and it was nowhere near as good out of the case.  I suspect it was sent to me straight as it came from Gibson.  However, I could tell it was a good 'un and after a quick tweak it's now on a par with my Peach R8.  Here's what you should check if the guitar isn't quite playing or sounding right to you:
1. Check the neck relief.  I use a capo and a 0.010" feeler gauge to set it accurately to my tastes, but for a quick check you can fret the low E string at the first and last frets and then look at the 8th/9th frets.  There should be a slight gap between the string and the frets.  If there isn't, loosen the truss rod a bit.  If there's a large gap tighten the truss rod a bit to straighten the neck.
2.  Check the action.  I measure it at on the open E strings at the 12th fret using a metal ruler and aim for the gap between the fret and the string to be between 1-2mm.  Adjust to taste and to avoid string rattle.
3.  Check the bridge saddles.  On my R9 the saddles were really badly cut, so bad that the top E string was vibrating against a burr and creating a sitar-like sound that stifled sustain.  Realising I didn't have the appropriate tools to fix the problem, I went on eBay and ordered this for £1.65 delivered:
https://www.ebay.co.uk/itm/Gas-Welding-Nozzle-Cleaners/172839188403
I've tidied up all the saddles now using the various thicknesses of files and finished off the job with a bit of wet and dry sandpaper to remove any sharp edges.  The guitar now sounds great and I have a pair of superb instruments.
I hope that helps anyone who has a slight setup issue with one of these great guitars.
«13
    Mine had the sitar type ring on the G string. I need to sort it out still
  • John_AJohn_A Frets: 3775
    Those nozzle cleaners are a bit OTT for cleaning up the saddles, a bit of wet and dry would be enough
  • TwinfanTwinfan Frets: 1625
    True, but mine needed a touch of enlarging so the nozzle cleaners were spot on.
  • mli3mli3 Frets: 206
    Thanks for this @Twinfan really useful.
  • crunchmancrunchman Frets: 11462
    They are quite handy for nuts as well if you don't want to pay for proper nut files (which are silly money).  On one of these I might pay for someone good to do it, but I don't mind messing with nuts on cheaper guitars.
    The nut was/is fine on my R9, it was only the saddles that were pretty poorly done.  Other guitars may vary of course!
  • grappagreengrappagreen Frets: 1346
    edited September 2018
    You’re having to this on a £2.5 - £3.5k guitar? (and this was cheap in comparison to RRP)
    Jeez..
  • Great tips thanks.
    Although my main observation is..... you bought both an R8 and R9?  That's a good 5 or 6k splashed out right there.  Will they ever leave the confines of your house?!
    It's just the usual Gibson QC stuff - they aren't PRS.
    I wonder what else gets through QC that can’t be so easily seen?
    Without wishing to sound crass, I currently gig a PRS that cost a lot more than both those guitars put together.  Don't assume what other people will or won't do with their guitars  ;)
    3reaction image LOL 0reaction image Wow! 6reaction image Wisdom
  • sweepysweepy Frets: 4190
    PRS aren’t that good out of the box either, they have a very “vanilla” setup
    True, but they don't have crappily cut nuts and bridges, colour bleed into bindings etc.
    Of all the PRS Guitars I’ve owned, which is at least over a dozen now,  I’ve had to recut the nut on every one of them as they are always left a bit high to take into account players that spank them harder than I do
    I've had 5 new PRS guitars over the years (US and SE) and I've never had one with a nut cut so horribly you couldn't tune it.  I've had it on a new Gibson.  I've also had other problems on Gibsons.  Not that my new R9 is like that - the set up is pretty good.
  • johnljohnl Frets: 2011
    An incorrectly cut nut is definitely something I'd be annoyed by but a quick tweak of the truss rod and lowering of the action (if desired) are things I would assume normal no matter what the cost of the guitar. Would be a bit like buying a Ferrari and then getting annoyed because you had to adjust the seat....
  • teradaterada Frets: 5114
    Jeez..
    A lot of this is because the guitars sold so quickly. Peach obviously did better with their pre-sale prep, but he guitars were a complete bargain, and adjusting the action/relief etc is hardly an arduous task.
    Also, to be fair, all my decent guitars go to Feline for a proper set up anyhow, which leaves them playing better than an average store tech could achieve (IMO).
    BTW. Nice thread @Twinfan, I'm sure many will find this info very useful
  • prlgmnrprlgmnr Frets: 3991
    At first glance I was a touch startled to see "gas welding nozzle" among the required equipment
  • gringopiggringopig Frets: 2648
    edited July 2020
