P9O mounting?
robgilmorobgilmo Frets: 3506
How do these mount to a guitar? and can you adjust their height? I see a lot of production guitars with p90's and cant see how they mount or adjust.
  • Adam_MDAdam_MD Frets: 3420
    They often screw directly into the wood with foam underneath to help adjust the height.
  • CorvusCorvus Frets: 2926
    Or with dogears you need spacers/risers which is more of a fiddle.
  • Reverend used to use brackets to mount them to a pickguard, just a strip of metal acting as a cradle IIRC, with screw holes on each end.
    Some folks like water, some folks like wine.
    My feedback thread is here.
    @TheGuitarWeasel makes them I believe.
  • Philly_QPhilly_Q Frets: 22995
    edited September 2018
    On Gibson SGs with the big batwing scratchplates, they mount the soapbar P-90s on upside-down dogear baseplates, then put threads on the feet so they can be height-adjusted at each end, like humbuckers (picture below).
    On SGs with small scratchplates the soapbars are just screwed directly to the body.
