Rabea has just done a video for The Kraken pedal. That model wouldn't be right for me as I'd love a crunch, more Plexi to 5150-ish sound and so I'd be looking at the other models.
I'm using a Divided by 13 single-channel amp and feel like I've got the best clean channel I'll probably ever get and absolutely love it. All my overdrive sounds come from pedals, singular use or stacking them, but it's still not the same, pleasing experience as a valve amp.
Thing is, they way I would want to use one of these pedals is in the Through Mode to retain my Divided clean preamp sound and use of the front panel amp controls, however, this means it needs to go into an FX Loop and my amp doesn't have one. Is there anything out there that can be plumbed in to effectively give you an FX Loop? I don't want to go down the second amp route, although the PRS MT15 Mark Tremonti lunch box head looks good for £100 or so pounds more or even the Laney heads with the fancy spec.
Well, that's any budget I had for something like this completely blown out of the water
As far as i understood it, the tubes in these are sub-miniatures that aren't socketed, they're soldered directly in, so there's no easy way of replacing them.
Were that the case, there would be no need for the enclosures to be so big.
