CT5... What to try next?
markblackmarkblack Frets: 1591
Hello all,
I've had a monteral assembly count to 5 for a while now and enjoyed messing around with it.
If i was looking something similar (odd but musical) what would you recomend?
Red panda partical?
The CT5 is bonkers and yes its tricky to get the same sounds twice but i don't mind that, just a bedroom player so practicality ain't that important :)
Cheers
Mark
  • Paul_CPaul_C Frets: 7807
    Of the multitude I have, the ones that I've found the most variety from are:
    Dr Scientist Bitquest
    Alexander Syntax Error
    Dwarfcraft Ghost Fax (and the Grazer, but not so much)
    and the Particle, which I like a lot too.
    And after all that, I would also recommend . . . two Count To 5s ;)
  • Chase Bliss Thermae. It isn’t massively “odd” but it is hugely musical. Thermae paired with a CT5 would be bliss
    How very rock and roll
  • GadgetGadget Frets: 896
    MWFX Judder
    I think, therefore.... I... ummmm........
  • Thanks all. Hi ho... Hi ho... Off to YouTube I go...
  • VJIvesVJIves Frets: 466
    MXFX Judder's great, Meris Enzo or Ottobit are both very satisfying, and maybe have a look at the Electro Faustus range? You should also have a look at the ridiculously cheap Walrus Descent that's on the FX sale classifieds, running the CT5 into that would make for some great combinations. With the Particle you might want to hold off until the version 2, I had a V1 and kept coming up with cool things that I was frustrated I couldn't save.
