Edit: Suppose running an extension lead from the house would be the easiest way to test if the garage's wiring is at fault.
Edit 2: sorry for the thread hijack @Calum13
It's certainly not good. It's not as dangerous as in the old days because a lot of modern appliances are double-insulated and don't need an earth, and modern distribution boxes are RCD, but it's not really safe.
Nil Satis Nisi Optimum
Sounds like an earthing problem then.
