They're great.
You're unlikely to be able to take it into the cabin without booking a seat - it will be far too large to go in the overhead bins. But with a Jazzmaster, I would risk it in the hold in that - Fender guitars are strong. You're actually more likely to have the case damaged than the guitar.
Sorry to be a party pooper but none of the cases mentioned so far is likely to be found for £50.
Travel by Ryan Air. Find out how much they try to charge the guitar for in-flight refreshments. :-p
The headstock on the jazzmaster clears the recess at the top of the case.
The skb case is fitted to the shape of the guitar. I don't believe the fenders are as they go for a vintage vibe.
I use my skb case over my fender CS case. It's more secure and weighs a lot less
