Why do les pauls come in 2 halves?
fastonebazfastonebaz Frets: 4095
Why are les paul bodies made from two pieces glued together in the centre as opposed to one single piece of wood? Or is it just the maple cap that's 2 piece and the mahogany is 1 piece?
  • hyperbenhyperben Frets: 1421
    Depends on the year, but a typical Les Paul is one piece mahogany back and 2 piece maple top
  • FelineGuitarsFelineGuitars Frets: 11594
    Gibson ones often come in a body and neck and a separate headstock ....just hanging there
    27reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • I don't think the number of pieces matters. I think my 1982 Standard has 3. It still sounds OK (but I'm aware there are other models that might sound better)
  • fastonebazfastonebaz Frets: 4095
    I just checked out the size of maple trees... I don't think they could make a one piece cap, they don't look big enough.  Guess that's why.
  • stonevibestonevibe Frets: 7143
    Depends on what size timber is available to use at the time, as they need to make thousands of guitars every year.
  • WhitecatWhitecat Frets: 5421
    They exist - PRS especially likes to do them occasionally. Rare-ish though for exactly the reason you give - you need a big tree.
    With Gibson, Custom Shop LPs will always have one-piece backs, but Gibson USA editions will usually be multi-piece (you do spot the odd one that is a one-piece though).
  • It’s the way violin tops  and acoustic soundboards are made.  It’s a beautiful bit of woodworking. The story is that they put the carved top on The Les Paul “because they could”.
  • GluedtoMusicGluedtoMusic Frets: 74
    edited October 2018 tFB Trader
    Les Pauls have what is called a book matched top, meaning the maple top starts out about 2" thick, they cut it in half to produce two 1" thick pieces and open them up like a book, this means the figure in the maple is a mirror image of its self on each side, and you get a nice consistent figure.
    Maple is plenty big enough for one piece tops but it is rare to get consistent figure across the whole top in enough quantities for a production line the size of Gibsons, the figure tends to be quite wild across the top.
    PRS do use them in their private stock guitars a fair amount:
    Supplier of Gotoh, Fender, Gibson, Faber, Schaller, Hipshot, Floyd Rose, TonePros, Graph Tech, Hosco luthier tools and many more.
  • DanielsguitarsDanielsguitars Frets: 3290
    Wrong I've got a one piece cap now on a burst I'm building , fantastic looking top but wasn't cheap, they don't seem very common
    www.danielsguitars.co.uk
    (formerly customkits)
    Would buy a one piece prs if I win the lottery.
    I've always wondered why Santana got a line down where the sides meet on his guitar. Guess he likes the way it looks.
  • HAL9000HAL9000 Frets: 9663
    On seeing the thread title, I must admit that my first thought was that the OP was referring to the headstock part and the rest of the guitar part.
  • WezVWezV Frets: 16671
    Trees come in all sizes, but finding a consistently figured 1 piece top is much harder than a 2-piece.
    Gibson copied other traditional instruments with this look..  violins also have 1 or 2 piece backs, but 2 piece is common on anything bigger than that.
    Not all Les Pauls are bookmatched, not even all the flamey ones
  • sweepysweepy Frets: 4184
    Two piece top and one piece body on my one
    https://i.imgur.com/DVNjSoq.jpg
  • ICBMICBM Frets: 72329
    It's an old woodworker's method of covering an imperfect seam. I assume the first one PRS made for him needed it, and he liked the look.
    The two lines between the pickups would have been the same, on a guitar with a full-width extended neck tenon - which I think the first all-mahogany one he had was. Notice they align with the edges of the neck.
     I seem to remember the early mahogany one has the tenon falling between the pickups, outlined in pearl and looks proper hokey.
    The two lines between the pickups on any later ones serve no function other than identifying it as a Santana model
    Ah yes - I think you're right, the tenon outline didn't go all the way to the bridge pickup. The production version with the lines *not* on the seam in the maple looks really odd too.
    It might also help explain why Mr. Smith was an early and enthusiastic adopter of CNC tooling as well ;).
    edited October 2018
    Here is one
    and a pre-production Santana model after someone had obviously had a word about the  line... notice the middle bit of maple doesn't match the rest of the (one-piece) top, so is likely capping a long tenon.  Modern ones are just a couple of pearl inlays with the normal PRS join
  • ArchtopDaveArchtopDave Frets: 1368
    edited October 2018
    It's down to the width of the wood available and aesthetics. There's much more useable wood available for 2 piece tops, and, indeed, 2  piece bodies. It can be quite hard to see the centre join on body wood if the grain pattern is nice and even. Also we've grown used to seeing nicely book matched tops.  As @customkits says, you can find good looking single piece tops, and backs for that matter, but they are significantly more expensive (supply vs demand).
    WezV said:
    Here is one
    I'd forgotten about the horribly crudely recessed bridge too!
    That's by far the best-looking of them.
  • Why are les paul bodies made from two pieces glued together in the centre as opposed to one single piece of wood? Or is it just the maple cap that's 2 piece and the mahogany is 1 piece?
    Pay the price for a custom shop Les Paul and you could get a one piece body.  More recently, bodies have been made with several pieces of wood. Two piece is top of the line.
    Home of the Ollandoc Guitar
    We Sell Custom Guitars & Guitar Kit
    www.rmolsonguitars.com
