I'm over weight now also thanks to the side effects of the tablets, something I must try to remedy really but it's not easy.
Good luck with your diet although exercise is probably just as important.
Can you have a hernia without it sticking out?
Get this, couple years ago they 'identified it' so put me on 2 lots of antibiotics long term which I'd have to rotate between every 2 weeks.
I was on them for a total of 7 months. Cost me a small fortune.
Probably became immune too.
Anyways fast forward to June 2018 and they've now said, well your tests from last year are strange.
One test indicates the bacteria is there.
The other test states its negative.
Her exact words were 'what a mystery'.
So they put me on another course of antibiotics for a couple weeks and said 'if you feel no better the bacteria probably wasnt ever there, so just um, buy some probiotics and see how you go'
I did ask them to just cut this trial and error and scooby doo mystery shit and just do another biospy, so we can all actually figure out whats going on and treat it accordingly.
They declined. I presume its too expensive, and that leaving the patient to their own devices to 'figure it out' is more cost effective for them.
Makes no sense though because I keep having to come back wasting more time, thus surely it would have been cheaper for them to do one procedure and nip the problem in the bud from day dot.
I dunno..
Put me in the queue for odd digestive issues.
I've had this intermittant pain in my general stomach area (below sternum) and a general load of burping and discomfort (but no acid reflux) for about 8 weeks
The docs first reaction was to stuff me on Omeprazole which I said I didn't want - 2 weeks on those and still no difference.
Went back and saw new practice partner who talked to me long and hard about lifestyle - told me to give up booze for a month and caffeine and limit dairy and wheat and take a good probiotic. Them come back and be tested for something called Helibacter pylori which can cause stomach ulcers which can give the symptoms i have.
2 weeks into detox and I think there may be the tiniest of improvement. But it's barely noticeable if I'm honest.
Im of course thinking I have stomach cancer
Seriously though, I had those symptoms once and it turned out to be H-Pylori. I think I got a course of two difference antibiotics (at the same time) and omeprazole. Been fine since
If you do Google it the closest you get is H Pylori and the ensuing peptic ulcer!!
Not shitting blood or losing weight so I'm guessing it's something to do with the cripplingly large amount of booze I've consumed in the last 12 months and my crappy stressy lifestyle
I was thinking more "on the left" "on the right, 4 inches from centre", under the ribs, lower down, etc
Really though, we're just kicking it around, you need to go through all the medical protocols to get to an answer
My pain was down to coeliac disease I eventually learned - it took years
Does eating yoghurt make pain go away?
