Pilot light will still turn on fine, but you will get no sound.
You probably need to change the power valve/s and replace the fuse.
I've just opened it up. All the valves are glowing and I found the old valves in a box, so swapped them one at a time but still no sound. Not even a hum when everything at 11.
If a power valve had blown the HT fuse, would the valves still get power? i presume not, but as I indicated - I'm know very little about amps!
Cheers.
I'll order valves / fuse later. Wisdom all round
P.s. Anything I can do to prevent another short or is it just pot luck?
What to do is not change the valves unless you actually need to - the failure rate is much higher with brand-new valves.
I murdered my noisy neighbours as well
New power valves and HT fuse and all is working again. Thanks for the assistance chaps.
