So now after watching several useful videos on YT including the very good peach demos. Sorry if this comes across as a little daft! I’m still a little baffled on how to access say five pedals/blocks when you only have the three physical switches, is this where the Snapshots come into use?
For one track that I play with my band I use a separate delay for slapback and long delay, a long ambient reverb, overdrive and a gain boost, during the chorus of the song the long delay and reverb are switched off and the slapback delay comes in for a lead part, when lead part is over both long delay and reverb continue. Overdrive is on throughout. Any help would be greatly appreciated
you can also use extra footswitches to give you up to 5 buttons to use for switching on/off blocks if the 3 snapshots turned out to be unusable
