That's a great flanger, I seldom turn mine off.
Cheers all - I'll probably just use the 12v setting from the Belcat power supply then. I'm probably a bit scared to mod the pedal myself. But you're right @JezWynd - it's basically the flanger sound I prefer compared to the more extreme, noisy ones I've had. Apparently plays rather nicely with drives as well. Plus, it's pink.
Depending on the PCB layout you can sometimes do it just with a small blob of solder between two of the pads, without even adding a wire.
