Thanks
If it's not that...
If it works with the pedal engaged then it cannot be a power supply issue. If it's directly-switched true bypass then it's the switch. If it's relay-switched then it will be the relay - I would guess relay switching is more likely since it has a stereo mode.
Either way it will be a fairly serious pain to work on. To get the PCB out you will need to undo all the pots, the jacks and the switch.
Thanks
soundcloud.com/thecolourbox-1
@ICBM you absolutely should insult my intelligence! I had no idea that I was even looking at a switch there! I will have a play when I get home and hopefully that will sort it.
Thanks for the help.
H
