Digitech RP-1000 For Sale - £175 shipped within UK.SOLD!
Excellent condition, rock solid unit and fully working. Original box and power supply included.
Also including an aftermarket Gator padded Gig Bag for this unit too.
This is an awesome pedal for doing the 4 Cable Method with any amp that has an Fx Loop. You're able to set up different FX blocks (Drive/Comp/Mod/Delay/Reverb etc) in front of the amp or in the Loop. And you can foot-switch 5 presets as well as 5 instant access switches at any time (for example you can foot-switch on/off any of the individual effects within a saved patch).
Also if your amp only has 1 channel, you can actually bypass your real amp's preamp section within any preset and use the built in amp modelling through your amp's power section. Crazy versatile!
There's also 1 Stomp Loop that you can put your favourite pedal in and switch it in/out anytime.
Basically a much more affordably priced version of something like a Fractal FX-8 or TC G-System etc.
PICShttps://ibb.co/mf40MLEmail me at
Dan@DanGowerAmps.co.uk if you want it or if you need any further info.
Cheers!
Dan
http://www.facebook.com/dgamps
http://www.instagram.com/dangower
