need Fender Dual Pot - struggling to find a UK stockist - any recommendations?
JMP220478JMP220478 Frets: 421
edited November 2018 in Guitar
Fender Dual 500k/250k Split Shaft Pot - 099-0847-000 needed  ( or decent equivalent ) for HSS strat build .. any UK stockists ?
cheers in advance
  • boogiemanboogieman Frets: 12426
    Tried Fender themselves?
    https://shop.fender.com/en-GB/contact-us
  • boogieman said:
    Good call  and have mailed them , tend to come to forum as get answers faster n without any bias ..
  • ICBMICBM Frets: 72642
    What's it to do - tone or volume? There are simple ways of wiring a HSS with standard pots and a resistor or two to give the correct loadings.
  • It’s vol with an bridge HB  n two singles - my experiences with a SD JB wired in on 250k are too dark in an MM Silo Special n my Shawbucker strat with a dual pot works really well .
    All you need is a 500K pot and a 470K resistor to lower the effective resistance when the single coils are selected.
    If it has a single tone control you can also use another resistor and a second cap to give 500K/.022uF for the humbucker and 250K/.047uF for the single coils.
    Any wiring diagram sites that illustrate this ?
    Cheers btw
    I don't know, but it's very simple. Are you using one tone control or two?
  • MM is single tone pot
    OK, so you just wire it like a normal VT Strat circuit with two 500K pots and a .022uF tone cap. This uses only one side of the selector switch.
    Connect the two switch rotors together as you would on a normal Strat. Then on the second side of the switch, connect the neck and middle terminals together, connect a 470K resistor to ground from there, and another 470K resistor in series with a 0.022uF cap to ground.
