I've been after a stereo set up for a while now and adding a second head and cab just isn't really happening as I can't find what I'm after really, well what I can afford too.
So as much as I love my amp I'm pondering selling it and my 2x12 to buy 2 used Twins. Which would probably leave me enough to buy a good drive pedal. I already have a Fredric Mutant Fuzz and a clone Super Hard On. So one that I would use a lot as my main drive sounds. American high gain stuff, SLO, Mesa type tones.
Anyone have any thoughts, or recommendations if going for this set up?
You'll be deaf with the Twins!!
Plus you need to match them up- like 100w or 135w then the speakers.
However, if you go for it, I'd get one Twin with crappy speakers, swap out for Celestion G12 75's for dirt, and then scour the net for my clean one, with the fabled JBL D120F's.
Keef R is all about Celestion's in Twins...it's a left field one but it works.
If you pan the two amps hard left and hard right through the PA, it would depend where you were in the venue as to how effective the blend would be. If you happened to be very close to the 'wet' side, you would hear mainly effected signal and very little dry - or vice/versa. For this reason, the FOH mix is almost always mono, or each 'side' panned only marginally to the left or right of centre.
