https://www.youtube.com/watch?v=UBbPMhdfmFc&t=275s
"Ramp - Adjusts how quickly the effect ramps up after the effect is turned on."
That's based on the old Boss VB2 'Rise Time' feature I assume, so it will kick in as soon as you turn the pedal on. It isn't envelope controlled. If you're into tinkering then you could dig into the Toneprint features via USB and make the effect less subtle when it reaches full ramp - most of the Toneprint pedals only reach their full potential after a bit of tweaking.
I wonder if there's another vibrato pedal that does what I want
