SOLD - XR400 MIDI thru + merge (5 in, 11 out)
This is a great problem solver for a MIDI system. It has 5 inputs and 11 outputs and allows you to set one pair as a master keyboard and one pair as a computer/sequencer. You can also choose one of the other three inputs as a merge source.
Then the smart stuff inside works out how to merge these and send the correct data to the outputs all WITHOUT creating a MIDI loop.
Also has a MIDI cable test facility (using Input C and output 3 on the front panel).
No manual, but thanks to the hero behind Muzines, you can get more info and work it out from the original review here:
http://www.muzines.co.uk/articles/xri-systems-xr400-midi-mate/128 - it will take a couple of read-throughs of that to get the hang of it, but once you're sorted it's very straightforward.
Price: £50 plus shipping (likely to be £10 for mainland UK) or collect from Cambridge
