I took this as part of a trade at the weekend on a tele I was going to sell so I need to sell this now. Although even though I'm a tele man I'm tempted to hang onto it! So here it is before I get too attached. Right so it is basically a 2008 American Deluxe Strat BUT with a USA Standard (american series) body from 2007 in Olympic White. All other parts ie neck/tuners/pups/pickguard/electrics/bridge/trem etc are from the deluxe, only the body is from the standard. So it has locking tuners, SCN pups, S1 switching, chromed saddles, deluxe bridge and trem with push in trem arm etc. The original owner wanted a white body, hence the swap. Superb condition, spotless, the deluxe neck has virtually no fret wear. Comes with a fender USA case I got with it, the shaped style, has a bit of damage at the top end but just to the outer plastic casing.
I wasn't sure how to price it, thought I'd aim somewhere between a good USA standard and a deluxe. Does £725 sound reasonable?
http://i1350.photobucket.com/albums/p767/johnswiss/_83_zps037e5908.jpg
http://i1350.photobucket.com/albums/p767/johnswiss/_84_zps52b955c8.jpg
http://i1350.photobucket.com/albums/p767/johnswiss/_81_zpsa3bfb189.jpg
http://i1350.photobucket.com/albums/p767/johnswiss/_86_zpsdabd09f7.jpg
Thought I'd add a bit more info. The deluxe neck is drilled to take both the deluxe screw configuration with cutaway and the standard more square config. As it's fitted to a USA standard body it has the square type USA neck plate fitted, but I will include the cutaway deluxe version neck plate. It also comes with the push in deluxe trem bar and some of the deluxe case candy like hangtags and manuals.
In the photos the trem is screwed flat but it is currently set up with trem working and a new set of D'addario 10s.
I'm open to any offers or trades as well.
Cheers
