Really high quality PA system. Two S218 subs with twin 18" drivers and Four F15 tops which have a 15" driver and 1.4" compression driver horn. The F15s can take around 1000w RMS each and the S218s can take 2000 W each so the whole system is capable of utilising around 8Kw of amplification. I do have some amplifiers for sale too which I will add soon. The M3 Controller is specifically designed to act as a crossover for these systems and is of very high quality with adjustable limiting for system protection. The subs come with the Martin protective lids and the F15s with Martin padded bags which are very durable. These are in good used condition and have only been used for about 40 gigs.
The F15s are £1000 a pair
The S218s are £1800 a pair
The M3 is £250
The whole package for £3500.
Collection near Hythe in Kent but I can also possibly deliver for an agreed rate and distance.
Manufacturers info below:
Martin F15
-Wide-bandwidth system
-Multi-angle birch ply enclosure
-User rotatable 80º x 50º horn
-0Top hat fitting for tripod mounting
-1.4” (35mm) compression driver
F15 technical specifications
TYPE Compact, two-way passive, multi-angled, vented
FREQUENCY
RESPONSE (1) 55Hz-18kHz ± 3dB
DRIVERS 15" (380mm) bass driver
1.4" (35mm) exit compression driver
RATED POWER (2) 400W AES, 1600W peak
RECOMMENDED 400-800W into 4 ohms
AMPLIFIER
SENSITIVITY (3) 99dB
MAXIMUM SPL (4) 123dB continuous, 129dB peak
IMPEDANCE 8 ohms nominal
DISPERSION (-6dB) 80º horizontal, 50º vertical
CROSSOVER 1.2kHz passive
ENCLOSURE 68 litre, multi-laminate birch ply
FINISH Textured black paint
PROTECTIVE GRILLE Black perforated steel
CONNECTORS 2 x Neutrik NL4
FITTINGS 12 x M8 inserts
Top hat fitting
DIMENSIONS (W) 471mm x (H) 690mm x (D) 443mm
(W) 18.5ins x (H) 27.2ins x (D) 17.5ins
WEIGHT 32.5kg (71.5lbs)
Martin S218
features
-Direct radiating 18” (460mm) drivers
-High temperature 4” (100mm) voice coil
-Fitted with handles and castors
S218 technical specifications
TYPE Dual-driver vented sub-bass system
FREQUENCY
RESPONSE (1) 35Hz-150Hz ± 3dB
DRIVERS 2 x 18" (460mm)
RATED POWER (2) 1000W AES, 4000W peak
RECOMMENDED 800-2000W into 4 ohms
AMPLIFIER
SENSITIVITY (3) 102dB
MAXIMUM SPL (4) 130dB continuous, 136dB peak
IMPEDANCE 4 ohms nominal
DISPERSION (-6dB) –
CROSSOVER 150Hz active
ENCLOSURE 320 litre, multi-laminate birch ply
FITTINGS 4 x 4" (100mm) castors
DIMENSIONS (W) 561mm x (H) 1066mm x (D) 780mm
(W) 22.1ins x (H) 42ins x (D) 30.7ins
WEIGHT 87kg (191.5lbs)S
Martin M3
features
-Dedicated Blackline Series controller
-2-way stereo operation
-Plug-in Blackline system-specific cards
-Advanced limiter design
-19" 1U standard rackmount
M3 technical specifications
INPUTS 2 electronically balanced
IMPEDANCE 20K ohms (10K ohms per leg single ended)
CMRR 60dB 20Hz – 10kHz
CONNECTORS 3 pin female XLR
OUTPUTS 4 electronically balanced
SOURCE IMPEDANCE 62 ohms
MIN. LOAD IMPEDANCE 600 ohms
MAX. OUTPUT + 20dBu into 600 ohms
CONNECTORS 3 pin male XLR
FREQUENCY -3dB @ 18Hz 12dB/octave
RESPONSE -3dB @ 45KHz 12dB/octave
(ultimately set by system parameters)
DISTORTION + NOISE 0.01% THD @ 2V output (limiters cancelled)
SIGNAL + NOISE
/ NOISE RATIO > 100dB @ 2V output
LIMITERS Individual for each channel
Ratio 20:1. Threshold range – 12dBu
to + 12 dBu in 16 steps
MAINS SUPPLY Captive 2m 3 core cable
with integral UK 3 pin plug
MAINS VOLTAGE Internally selectable by hard wire link
100-120/220-240V. AC, 50/60Hz
Voltage tolerance on each setting ± 10%
MAINS FUSE 100-120V and 220-240V: 160mA Type ‘T’ (L)
DIMENSIONS (W) 482mm x (H) 44mm x (D) 155mm
(W) 19ins x (H) 1.7ins x (D) 6.1ins
WEIGHT 2.4kg (5.28lbs)
