Up for sale here is my Palmer PDI-09 DI box with built-in cabinet emulation. It is a superb sounding unit with a solid build quality (made in Germany!). It is in very good condition and it is fully functional.
I have found it incredibly useful, having it attached to the back of a cabinet (hence the velcro on the back of the unit) and being able to feed the front of house with a reliable, consistent signal every gig.
Price assumes PayPal gift and includes delivery. SOLD ON EBAY
Manufacturer's blurb:
The PDI09 DI Box for guitar simply does what all guitarists have wanted since guitar amps began: it takes the speaker output and splits it, sending the powered load back to the speaker cab (or a dummy load) and whisks the rest of the signal through Palmer's fabled speaker emulation filters and to a balanced XLR output read to go to front of house or a mixing desk!
Perfect for vintage amps or smaller combos that don't have a dedicated line out, though remember the load from a valve amp HAS to stop somewhere, either a speaker or a dummy load. You cannot just plug a valve power output into the PDI09 without connecting anything to the 'thru'.
Take all of the hassle out of micing up your vintage amp on-stage and get consistant reliable sound that isn't going to stop when your over-eager lead singer kicks over the microphone infront of your cab!
Suggested Settings
15W amp - no attenuation
50W amp - 15db attenuation
100W Amp - 30db attenuation
Classic British tone - Filter Switch to Bright
Classic American tone - Filter Switch to Mellow
The PDI09 can be connected between an effect device or amplifier and the mixing console. The PDI09 is not suitable for direct connection to a guitar. Integrated filter circuits simulate the authentic "speaker" sound. Tone can be varied between "Mellow", "Normal", or "Bright".
Specification
Product type: speaker simulator
Type: passive
Channels: 1
input type: unbalanced
Inputs: 1
input connectors: 6.3 mm Jack
output type: balanced
Outputs: 1
output connectors: 6.3 mm Jack, XLR
output impedance: 600 Ohm(s)
controls: voicing, attenuator
dummy load: no
max. load: max. 200 W
voicing filter: yes
power attenuator: no
transformer isolated outputs: yes
cabinet material: die-cast aluminium
Cabinet / Housing surface: powder coated
Width: 120 mm
depth: 60 mm
height: 35 mm
