Help identifying this gibson...
poopotpoopot Frets: 9099
right then, a guitar has been dropped off to a pals for some tlc... gibson 12 string... we’re told pre 60’s... no serial and no model number anywhere...
fancy a game of “name that guitar”...
  • KKJaleKKJale Frets: 982
    edited December 2018
    Gibson B45-12.
    Edit: the book says no trapeze/upper belly bridge should be '62-'65. Probably the only way to narrow it down would be to discover a batch number stamped somewhere inside...
  • ICBMICBM Frets: 72444
    It's also early 1960s and not pre-60s. The model was made from 1961 onwards, but I think the earliest had 'slope' shoulders which this one doesn't, and from 1965 onwards they changed to a trapeze tailpiece, so I would guess more like 1963-64.
  • poopotpoopot Frets: 9099
    Cheers chaps... allegedly used on the start of space odity and here comes the sun!!!!!
  • AliGorieAliGorie Frets: 308
    N.B. it has the classic Gibson - headstock / neck crack / break -
    be aware.
    That actual one?!
    be aware.
    Looks to have been reasonably well-repaired and not a complete clean-off in the first place, but yes be aware.
    be aware.
    Yep... not mine so don’t care :)
    ICBM said:
    That actual one?!
    Apparently so!... need to do a bit more digging but looks to be the case!
