Never heard an Epiphone Valve Junior sound like this before!!!
longjawlongjaw Frets: 423
The guitar probably helps too mind!
  • mixolydmixolyd Frets: 826
    edited December 2018
    The EVJ can certainly bark and grind when you crank it but it has a tendency to sound pretty dark.  That old LP is probably pretty bright for a humbuckers guitar thanks to low output PU’s.
    It helps that they’re using the cabinet - my best results with the VJ have been when using cabinet sims to PA, then it can sound gigantic.  Still pretty much a one trick pony though.
    Also there’s a lot of room sound in that video which takes away from the one dimensional impression the amp can give.
  • It doesn't sound great, hence all the verb. Now if they'd plugged into an AC30!
  • ICBMICBM Frets: 72642
    Less shit than usual? Yes, if you’re familiar with what great guitars through bad amps sound like, you can almost hear how good the guitar is :).
